20 years agoHelp writing c code for NiosII_Stratix II_2s60
Hi at all! This is my first post. I would like to have some advice to write the c code for my thesis. I have to use a NiosII_Stratix II_2s60. I have started from the example present in kits/nios...
JOHI
Contributor
8 years ago
Hello SS5,
Welcome to the forum,
The board package contains demo code "OpenCore Plus evaluation of the Altera Triple-Speed Ethernet IP Core and supporting design example" This demo is a good place to start to get you up to speed with the TCP/IP stack.
Then, you can make several test projects for the various components of your project, test them with Modelsim and assemble your components to obtain your final project.
Please do understand that we can only try to help you with specific technical questions regarding problems where you are stuck.
Johi.
