21 years agohelp on SDRAM
Hello. I have a big problem with my board. My board has a EP1CQ240C6, one flash Intel E28F128, one SDRAM MT48LC4M32, one EPCS4 and a LAN91C111. The CPu clock is 50 MHz. I have made a...
21 years agoHi sol,
While not SDRAM-specific, there is a document in Nios II 5.0 which may help you understand how to calculate phase-shift values and determine how fast you can run SDRAM without using a PLL for phase-shifting. The document describes the new SSRAM interface in Nios II 5.0 and is "ssram_interface_readme.html" in the Nios II installation's 'documents' folder. You should study carefully the first section that describes the memory interface with no phase shift -- it will show you how to calculate the maximum speed which you can run with no phase shift. You will need: 1. To obtain the data sheet for your SDRAM and examine timing parameters (Tsu, Tco for all inputs, worst-case) 2. Look at the quartus timing analysis report for Tco and Tsu times for all pins to and from SDRAM 3. Perform timing analysis to see what f-max you can run at with no phase shift Important note: Even without a PLL there will be a phase-relationship between FPGA (Avalon) clock and the clock you drive from the FPGA to SDRAM. You should be able to find this delay in the Quartus Tco report. Good luck!
