14 years agohelp: niosII and pof/sof
Hello, Hopefully this has a simple solution. I have a board with an Arria GX which can be programmed with through an active serial EPCS64 using a pof file. I've created a very simple syst...
14 years agoWhen you download .sof file, you must make the button of DE2 borad on RUN, and when you download .pof file ,you have to make the button of DE2 borad on PROG, so I think you may not make the button on PROG,it is sure be failed.
