14 years agohelp: niosII and pof/sof
Hello, Hopefully this has a simple solution. I have a board with an Arria GX which can be programmed with through an active serial EPCS64 using a pof file. I've created a very simple syst...
14 years agoHi Daixiwen,
I'll give your method a shot too. I need to do a little research on your suggestion. I've not used the EPCS core nor have I programmed the flash using anything besides the pof created by QII.
