14 years agohelp: niosII and pof/sof
Hello, Hopefully this has a simple solution. I have a board with an Arria GX which can be programmed with through an active serial EPCS64 using a pof file. I've created a very simple syst...
14 years agoUsing a .sof is easier during development because you don't have to program the flash.
Do you have a usb blaster connected in JTAG mode with the FPGA? Is the FPGA detected correctly by the Quartus programmer? Did you enable the JTAG debug module in the Nios CPU?
