15 years agoHelp-load uclinux on FPGA
Dear friends, Recently I have a try for loading uclinux on FPGA. And I do it as Altera wiki-Install Nios II Linux. http://www.alterawiki.com/wiki/install_nios_ii_linux And when...
14 years agohw_select doesn't work any more
you need to create header file with sopc2swheaders script and use it The wiki is not updated, some times it is a mix of old and new. your problem could be missing packages.
