15 years agoHelp-load uclinux on FPGA
Dear friends, Recently I have a try for loading uclinux on FPGA. And I do it as Altera wiki-Install Nios II Linux. http://www.alterawiki.com/wiki/install_nios_ii_linux And when...
15 years agoare you sure that the hw_select shall be done?
If you follow latest branches (see http://www.alteraforum.com/forum/showthread.php?t=31829), the device tree fashion should be followed. hw_select is the way that was used in the old nioswiki times.
