14 years ago
help generate the zImage
I'm trying to make uClinux's zImage by executing command "make" after i have done the "make menuconfig" and "make vendor_hwselect" successfully, but the process always executing the some code, the following code are part of it:
  2               DGRAM                    14288
unix  2               DGRAM                    14381
unix  3               DGRAM                    9624
unix  3               DGRAM                    9623
unix  2               DGRAM                    9398
unix  2               DGRAM                    9397
zip error: Nothing to do! (6/ddp.zip)Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address               Foreign Address             State
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags       Type       State         I-Node Path
unix  26              DGRAM                    1796   /dev/log
unix  2               DGRAM                    1805   /run/systemd/shutdownd
unix  2               DGRAM                    1861   @/org/kernel/udev/udevd
unix  2               DGRAM                    8564   /run/systemd/notify
unix  3               STREAM     CONNECTED     135793 /home/hanxu/.pulse/03150a200ccbe5c4977b361c00000014-runtime/native
unix  3               STREAM     CONNECTED     136789
unix  3               STREAM     CONNECTED     134120 @/tmp/dbus-2sNK3v4L
unix  3               STREAM     CONNECTED     134119
unix  3               STREAM     CONNECTED     134636 @/tmp/dbus-accCQ7gn3g
unix  3               STREAM     CONNECTED     134097
unix  3               STREAM     CONNECTED     134083 @/tmp/dbus-accCQ7gn3g
unix  3               STREAM     CONNECTED     134082
unix  3               STREAM     CONNECTED     134080 @/tmp/dbus-accCQ7gn3g
unix  3               STREAM     CONNECTED     134594
unix  3               STREAM     CONNECTED     134593 @/tmp/.ICE-unix/1632
unix  3               STREAM     CONNECTED     134592
unix  3               STREAM     CONNECTED     134071 @/tmp/.X11-unix/X0
unix  3               STREAM     CONNECTED     134549
unix  3               STREAM     CONNECTED     111122 /var/run/dbus/system_bus_socket
unix  3               STREAM     CONNECTED     112010
unix  3               STREAM     CONNECTED     111116 /tmp/orbit-hanxu/linc-12f2-0-2a10c26aec2c
unix  3               STREAM     CONNECTED     112009
unix  3               STREAM     CONNECTED     112008 /tmp/orbit-hanxu/linc-6b4-0-61155ec35924a
unix  3               STREAM     CONNECTED     111114
unix  3               STREAM     CONNECTED     111095 @/tmp/dbus-accCQ7gn3g
unix  3               STREAM     CONNECTED     111997
unix  3               STREAM     CONNECTED     111090 @/tmp/dbus-2sNK3v4L
unix  3               STREAM     CONNECTED     111993
unix  3               STREAM     CONNECTED     111083
unix  3               STREAM     CONNECTED     111082
unix  3               STREAM     CONNECTED     111080 @/tmp/.ICE-unix/1632
unix  3               STREAM     CONNECTED     111970
unix  3               STREAM     CONNECTED     111956 @/tmp/.X11-unix/X0
unix  3               STREAM     CONNECTED     111955
unix  3               STREAM     CONNECTED     84577  @/tmp/dbus-accCQ7gn3g
unix  3               STREAM     CONNECTED     84576
unix  3               STREAM     CONNECTED     32551  @/dbus-vfs-daemon/socket-1VOtJCXs
unix  3               STREAM     CONNECTED     32550
unix  3               STREAM     CONNECTED     32552  @/dbus-vfs-daemon/socket-1of8MTTR
unix  3               STREAM     CONNECTED     32549
unix  3               STREAM     CONNECTED     32542  @/tmp/dbus-accCQ7gn3g
unix  3               STREAM     CONNECTED     32541
unix  3               STREAM     CONNECTED     32425  @/tmp/dbus-2sNK3v4L
unix  3               STREAM     CONNECTED     32424
unix  3               STREAM     CONNECTED     32423  @/dbus-vfs-daemon/socket-VxPLb4zk
unix  3               STREAM     CONNECTED     32422
unix  3               STREAM     CONNECTED     32421  @/dbus-vfs-daemon/socket-DMo2AJtV
unix  3               STREAM     CONNECTED     32420
unix  3               STREAM     CONNECTED     31633  @/dbus-vfs-daemon/socket-FMBnlpZE
unix  3               STREAM     CONNECTED     31632
unix  3               STREAM     CONNECTED     31634  @/dbus-vfs-daemon/socket-0kWNSiNm
unix  3               STREAM     CONNECTED     31631
unix  3               STREAM     CONNECTED     31625  @/tmp/dbus-accCQ7gn3g
unix  3               STREAM     CONNECTED     32412
ps:I use the .ptf file provided in wiki and in "make menuconfig" I choose Default all Settings.
can anybody help me?
thanks in advance.
    I have known the answer. the zImage must be make under linux's file system.
