vgovi3
7 years agoHello I would like to use the on-chip RAM in quartus for a custom design which doesnt use the avalon bus.Could you please advise me which component from the ip library catalogue i should use as the memory controller ?
AnandRaj_S_Intel
7 years agoHi,
Do you have Qsys system? avalon interface will be used inside Qsys system (Nioss II , On-chip ram, Jtag uart ..etc) ?
You can create a Top level file and instantiate both Qsys system and your custom design.
So that you can use on-chip ram memory
or
You want to use only memory for your design?(without avalon interface /Qsys system)
Simply use the memory template available in quartus (Edit->insert template->verilog HDL->Full design->RAM and ROM's ->select the required design)->save it and use it in you top level module/entity.
Anand Raj Shankar
