9 years agoH2F Bridge EMIF Access
Hi, I am using an Arria 10 ReFLEX Achilles dev kit that includes 2 DDR4 memories. The first DDR4 is used by the HPS and the second one I am trying to access from the HPS as well. To do this, I am ...
9 years agoHi here is a small update,
I decided to remove the address span extender to see if that was actually the cause of my distress. It turns out that the EMIF connected to the bridge is not working properly. However, I did add the peripherals on and now it does not work; so the next step for me is to remove the peripherals and confirm the functionality of the DDR4 without it. Any tips on how to test the RAM functionality would be great. Right now I am just writing, then reading to see if I get the same value. The next thing I was thinking of is writing from HPS, then read it from the FPGA side and loop it back to the HPS using a bridge.
