9 years agogot this error when using eclipse
hi everyone..can u tell me why i got this error in my eclipse? make: *** [proj_Trafflight.elf] Error 1 proj_Trafflight C/C++ Problem i already try to solved this error...but it's sti...
9 years ago --- Quote Start --- i already overwrite the 32 and 64 bit cygwin..but this error was popup.. Description Resource Path Location Type -O0: g++: command not found proj_NiosIITrafficlight_bsp [Discovery Options] page in project properties C/C++ Problem Program "make" is not found in PATH proj_NiosIITrafficlight C/C++ Problem is it im doing wrong or i missed something? im really need your help because my eclipse seem doesn't like me.. :p:p --- Quote End --- I am afraid you have installed the file incorrectly. So the software is unable to locate the g++ file. :cry: you need to reinstall the software as the files are overwritten in the wrong location. After you install the Altera software again. Install the cygwin for 32 and 64 bit in any folder of your drive. No need to locate the Quartus software while installing the cygwin files as it will be a bit confusing. When you install the cygwin files in different folder of the drive two folder will create name as Cygwin and cygwin 64. First open the folder cygwin. it is for 32 bit. Inside you will see the files as "bin, dev, etc, home, library, cygwin.bat" and so on. Select all and copy the files in the location as altera<version<quartus<bin<cygwin. paste the files inside the cygwin folder of the quartus software, replace the files when a pop will appear. Repeat the same steps for cygwin 64 also. it will be in bin 64 of the quartus. And bingo!!!!:cool: Let me know if you face any problem while updating the files.
