21 years agoGoAhead Webserver
hello there, anyone know how to port the goahead webserver to NIOS2? Thnx
21 years agoIf you follow the instructions in the tutorial you can look at the command line options
COMMAND_PREFIX := nios2-elf- The CFLAGS will vary depending upon your hardware these will work for a Cyclone part CFLAGS = -g -O3 -ffunction-sections -fdata-sections -fno-rtti -fno-exceptions -fvtable-gc -DSYSTEM_BUS_WIDTH=32 -mhw-mul -mno-hw-mulx -mno-hw-div If you have a Stratix part or a hardware multiply/divide unit you may wish to change these to use the multiply unit and generate faster code nios2-elf-gcc --help will provide more information on what the options mean
