13 years agoGetting data from a rtc device through I2C
Hi all, I would like to retrieve information from a RTC device which is directly connected to a GPIO, using the i2c protocol. So, the first step was to load the i2c-gpio driver with this piece ...
9 years agoIn the i2c-gpio method, SCL and SDA signals are generated directly by your Nios CPU, and this is the reason why the SLC clock period is not constant. If you have any doubt, there is another way to use an 'opencore's i2c core'.
