16 years agoGerber Files
Would somebody please direct me to a forum that knows about Gerber files... BAK Backup file for PCB layout BMK Bottom mask gerber file BOT Bottom layer gerber file BPS Bottom past...
16 years agoWow you do know your stuff... I am amazed at the size and scope of
Altera/Quartus... Can you answer me one question....I have reviewed the file types within the Quartus II software: and they are the following: .vhd, .ddb, .dxf, .dqs, .ref, .hpp, .cpp, .cdb, .rdb, .cbl, .sci, .options, .tcl, .tmf, .ipx, .hsd, .pkg, .lmf, .itk, .oaw, .xsd, .ttf, .rbf, .jbc, .svf, .jam, .hexout, .maxplus2, .logic, .tpl, .dacr, .pll, ..etc..etc... A project file in Quartus has these file extensions: .fsf, .tdf, .cmp, .rpt, .ssf, .qws, .psf, .pin, .eqn, .csf, etc..etc.. and the Gerber file extensions: .tsk, .bmk, .bot, .bps, .bsk, .drl, .gnd, .pcb, .tmk, .top, .tps....etc... I realize that the file extensions above are for a lot of different processes... I am sure you would recognize a lot of them... .tcl, .cpp, .dxf ...some linux extensions, some scripting languages (perl)... I am not an electrical engineer... I have a computer science degree and math degree... I want to understand the logic behind Altera/Quartus... In simple terms: a standard motherboard... has power supply, electronic components, I/O devices, chips, memory, intel, amd, etc...pin placements, etc... It would seem the Gerber extensions has the electronic structure for the motherboards....I don't see how Altera has a totally different structure... Is this the Bill Gates syndrome... All over again... An electronic structure built around Altera/Quartus???? Where does Gerber fit in ???? Please forgive my stupidy on this... I want to understand how they have integrated the design process in creating/making the motherboards ???? From concept to final product...
