15 years agoGenerating Hierarchical Systems in Qsys
hi I implement a top level system, which is a multiprocessor system, with Qsys then generate the top level system for making subsystem's .SOPC file, but it does not make that. I am so confused, ...
15 years agoIf you are creating the system in Qsys, you won't find SOPC files. The subsystem components will be Qsys files. If you have a Qsys system in your active Quartus project and you open Qsys, it should appear at the top of the Component Library window under Project-System.
