9 years agoGenerating BSP failed: Cpu reset memory has no matching memory region.
Hello Everybody, I have a Nios II /f that runs "Hello world" properly on a DE2-115 in Q16.0 using FPGA on chip memory. The system is as simple as possible, cpu, jtag, ram, sysid, it runs at...
9 years agoAs Johi says above, you need to edit the BSP. On the Linker Script tab various memory regions are defined. What you will probably find is that the reset region in the BSP is still pointing to the on-chip RAM.
