14 years agogenerate system from qsys ?
I could not achieve simple nios system...
which consist of *cpu *memory(on chip RAM with 8129 byte) *jtag(default setting) *output IO I could not make it working in quartus. :S2 Replies
What is your problem? "not make it working" it a rather vague description.
Are you using a kit? They all come with example designs. - Altera_Forum
Try going through the Nios II hardware tutorial:
http://www.altera.com/literature/tt/tt_nios2_hardware_tutorial.pdf http://www.altera.com/literature/tt/niosii_hw_dev_tutorial.zip
