15 years agoGCC and FPU
Hello everyone, I am porting some legacy code which uses double precision floating point. Changing double to single fp or fixed point would require a major rewrite which I want to avoid. ...
15 years agoThanks for the explanations and suggestions.
3 instructions per op are not a big issue with e.g. division which takes 10 cycles, but compare can be done in one cycle. Anyhow I think the real issue is register allocation and optimization. I have a reference hardware - powerpc with floating point unit which has 32 internal double precision registers. With it gcc can produce much faster/smaller code - in some of my cases more than 2-3x times faster.
