15 years agogate level simulation problem
Hello, I am working on a DVI interface, I am sending video data serially, every thing work well, apart from the post place and route simulation, I have this worning and I didn't get any thing.# ** W...
15 years agoThank you for your help, I've connected all ports in test bench but I still have this errors and wornings, seems like no librarie is taken in account:
# ** Warning: (vopt-1946) simulation/modelsim/dvi_mainTOP_vhd.sdo(132637): Can't resolve SDF pathname "outclk_and" - instance not found.# ** Warning: (vopt-1946) simulation/modelsim/dvi_mainTOP_vhd.sdo(282567): Can't resolve SDF pathname "outclk_and" - instance not found.# ** Warning: (vopt-1946) simulation/modelsim/dvi_mainTOP_vhd.sdo(151056): Can't resolve SDF pathname "outclk_and" - instance not found.# ** Warning: (vopt-1946) simulation/modelsim/dvi_mainTOP_vhd.sdo(146446): Can't resolve SDF pathname "outclk_and" - instance not found.# ** Warning: (vopt-1946) simulation/modelsim/dvi_mainTOP_vhd.sdo(211377): Can't resolve SDF pathname "outclk_and" - instance not found. # ** Error: (vsim-SDF-3250) simulation/modelsim/dvi_mainTOP_vhd.sdo(145519): Failed to find INSTANCE '\stratix_reset_n~input\'.# ** Error: (vsim-SDF-3250) simulation/modelsim/dvi_mainTOP_vhd.sdo(164549): Failed to find INSTANCE '\stratix_reset_n~inputclkctrl\'.# ** Error: (vsim-SDF-3250) simulation/modelsim/dvi_mainTOP_vhd.sdo(164549): Failed to find INSTANCE 'outclk_and'.# ** Error: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s). # ** Warning: (vsim-8683) Uninitialized out port /dvi_maintop_vhd_tst/i1/altera_internal_jtag/tdo has no driver.# This port will contribute value (U) to the signal network.# Region: /dvi_maintop_vhd_tst# ** Warning: (vsim-8683) Uninitialized out port /dvi_maintop_vhd_tst/i1/altera_internal_jtag/tmsutap has no driver.# This port will contribute value (U) to the signal network.# Region: /dvi_maintop_vhd_tst# ** Warning: (vsim-8683) Uninitialized out port /dvi_maintop_vhd_tst/i1/altera_internal_jtag/tckutap has no driver.# This port will contribute value (U) to the signal network.# Region: /dvi_maintop_vhd_tst# ** Warning: (vsim-8683) Uninitialized out port /dvi_maintop_vhd_tst/i1/altera_internal_jtag/tdiutap has no driver.# This port will contribute value (U) to the signal network.# Region: /dvi_maintop_vhd_tst# ** Warning: (vsim-8683) Uninitialized out port /dvi_maintop_vhd_tst/i1/\serdes_instG|altgx_core_alt4gxb_component|cal_blk0\/nonusertocmu has no driver.# This port will contribute value (U) to the signal network.# Region: /dvi_maintop_vhd_tst what could be causing these errors ? thank you again...
