14 years agoFull duplex communication on a TCP socket
Hi, Is it possible send a character command from a client to a server if server is still sending data continuously to client?....so...I mean....during server->client data sending...? Regards
14 years agoUnless 'continously' means the server is flooding the socket with data and is using most of cpu time, full duplex communication is possible; as a matter of fact I dare say it's a common situation with TCP sockets.
You must also consider your physical layer and link level. Some transmission media is inherently half duplex, although I think you are using a 100Mb or Gb Ethernet interface which both support full duplex transmission. With Nios these lower layers are normally not a problem and the bottleneck is the software side (TCP stack management and application).
