15 years ago
ftp session problem
Thanks in advance.
I've got a custom embedded uClinux NIOS system with a compact flash (I use ext3). The system records *.bin files and we extract them via ftp using "mget." After a few files I get
425 Can't open passive connection: Cannot assign requested address.
Passive mode refused. Turning off passive mode.
I have used the 2c35 evaluation board to recreate the problem AND do ftp with debug on. I higlighted the output problem with "italics"
It appears that the CLIENT gets confused and tries to open the port
using IT'S ip address. I did some googling and am basically don't have
any good ideas how I can prevent this problem.
Any solutions, things to try, ... WOULD BE GREATLY APPRECITED.
FTP Session Linux client to Evaluation Board (same FTP server). With
DEBUG VERBOSE (-dv) enabled (NOTE: apwr is set in my Network stuff so
I don't have to type 129.131.7.220 all the time). Also the IP address of the Linux
machine I was running the client upon was 129.131.7.14.
TRIED WITH WINDOW ftp client and same story ...
[janet@localhost ~]$ ftp -dv apwr
Connected to AARGMpwr.
220- Welcome to the uClinux ftpd!
220 uClinux FTP server (GNU inetutils 1.4.1) ready.
ftp: setsockopt: Bad file descriptor
---> AUTH GSSAPI
500 'AUTH GSSAPI': command not understood.
---> AUTH KERBEROS_V4
500 'AUTH KERBEROS_V4': command not understood.
KERBEROS_V4 rejected as an authentication type
Name (apwr:janet): ftp
---> USER ftp
331 Guest login ok, type your name as password.
Password:
---> PASS XXXX
230 Guest login ok, access restrictions apply.
cmds.c:276: verbose=2 debug=1 overbose=2
---> SYST
215 UNIX Type: L8 Version: uClinux 2.6.30
Remote system type is UNIX.
Using binary mode to transfer files.
ftp> ls
ftp: setsockopt (ignored): Permission denied
---> PASV
227 Entering Passive Mode (129,131,7,220,160,219)
---> LIST
150 Opening ASCII mode data connection for '/bin/ls'.
226 Transfer complete.
ftp> passive
Passive mode off.
ftp> passive
Passive mode on.
ftp> mget *.bin
---> PASV
---> NLST *.bin
mget PWR_01-01-00-00.01.18.bin? y
---> TYPE I
200 Type set to I.
---> PASV
227 Entering Passive Mode (129,131,7,220,184,190)
---> RETR PWR_01-01-00-00.01.18.bin
150 Opening BINARY mode data connection for 'PWR_01-01-00-00.01.18.bin' (43657216 bytes).
43657216 bytes received in 47 seconds (9.1e+02 Kbytes/s)
mget PWR_01-01-00-00.02.40.bin? y
---> PASV
227 Entering Passive Mode (129,131,7,220,176,103)
---> RETR PWR_01-01-00-00.02.40.bin
150 Opening BINARY mode data connection for 'PWR_01-01-00-00.02.40.bin' (1232896 bytes).
1232896 bytes received in 1.4 seconds (8.4e+02 Kbytes/s)
mget PWR_01-01-00-00.02.41.bin? y
---> PASV
227 Entering Passive Mode (129,131,7,220,219,122)
---> RETR PWR_01-01-00-00.02.41.bin
150 Opening BINARY mode data connection for 'PWR_01-01-00-00.02.41.bin' (10937344 bytes).
11175936 bytes received in 15 seconds (7.3e+02 Kbytes/s)
mget PWR_01-01-00-00.03.18.bin? y
---> PASV
227 Entering Passive Mode (129,131,7,220,179,173)
---> RETR PWR_01-01-00-00.03.18.bin
150 Opening BINARY mode data connection for 'PWR_01-01-00-00.03.18.bin' (4663296 bytes).
4663296 bytes received in 5.1 seconds (8.9e+02 Kbytes/s)
mget PWR_01-01-00-00.06.23.bin? y
---> PASV
227 Entering Passive Mode (129,131,7,220,229,249)
---> RETR PWR_01-01-00-00.06.23.bin
150 Opening BINARY mode data connection for 'PWR_01-01-00-00.06.23.bin' (23447552 bytes).
23447552 bytes received in 25 seconds (9e+02 Kbytes/s)
mget PWR_07-14-11-17.20.13.bin? y
---> PASV
---> port 129,131,7,14,220,164
500 Illegal PORT Command
ftp: bind: Address already in use
mget PWR_07-14-11-21.02.42.bin? y
---> port 129,131,7,14,207,36
mget PWR_07-14-11-21.03.25.bin? y
---> port 129,131,7,14,229,98
mget PWR_07-15-11-15.22.29.bin? y
---> port 129,131,7,14,164,234
mget PWR_07-15-11-16.02.54.bin? y
---> port 129,131,7,14,172,37
mget PWR_07-15-11-16.14.25.bin? y
---> port 129,131,7,14,186,147
mget PWR_07-15-11-16.21.58.bin? n
mget PWR_07-15-11-22.35.36.bin? n
ftp> quit
---> QUIT
221 Goodbye.
    I don't know exactly what you did to get these messages
    ---> AUTH GSSAPI
    but they probably has something do with this problem.
    And there is also the problem that you didn't login with the right acount.
    You just used the "guest" account which is not able to your commands.
    So try to use the "root"-account from you uClinux board when logging in.
    Urmel (and anyone else),
    What you have commented upon has nothing to do with my problem. When you use NIOS2 with uClinux you typically use GUEST ftp login.
    "ftp" with no password and you can only work in "/home/ftp" defined in "passwd" So I changed the "passwd" file to point to my compact flash.
    so i am logged on properly and i can transfer files for awhile.
    MORE INFORMATION --
    I added a user in "passwd" and loggeed on to FTP as a user so that the FTP transactions WERE NOT as a GUEST and I still get the same problem.
    Thanks in advance.
    FIXED THIS ISSUE --
    Problem is a bug in the uClinux ftpd.c code.
    I found a blog from 2003
    http://blog.gmane.org/gmane.linux.uclinux.devel/month=20061101/page=36
    Code here just in case this link is flakey
    Subject: [BUG] ftpd
    Newsgroups: gmane.comp.gnu.inetutils.bugs
    Date: Fri, 29 Aug 2003 21:28:31 +0900
    Hello
    I found a bug.
    if "nm ftpd | sort -n" show:
    1001cba8 b bufs.135
    1001ce78 b ctrl_addr
    1001ce88 b data_source
    then ctrl_addr will be destroyed, and ftp client
    will get message like this:
    425 Can't create data socket (56.0.0.135,0): Cannot assign requested
    address.
    diff -u ftpd.c_org ftpd.c
    --- ftpd.c_org Wed Jun 26 12:15:05 2002
    +++ ftpd.c Fri Aug 29 21:15:41 2003
    @@ -192,7 +192,7 @@
    static char bufs[NUM_SIMUL_OFF_TO_STRS][80];
    static char (*next_buf)[80] = bufs;
    - if (next_buf > (bufs+NUM_SIMUL_OFF_TO_STRS))
    + if (next_buf >= (bufs+NUM_SIMUL_OFF_TO_STRS))
    next_buf = bufs;
    if (sizeof (off) > sizeof (long))
    When I introduced this change in my ftpc.c the problem is resolved.
    Anyone have any further comments on this and/or the above mentioned bug
    report?
    /Martin
    Basically, a fix for this problem was submitted way back then and is not in the current "ftpd.c" file (in uClinux-dist/user/ftpd directory). I made the fix, tested it and it works great. I can now mget with no problems.
    Hope this helps someone else.
