15 years agoFPGA image in flash/boot copier
What should the offset be for the FPGA image in CFI flash be if I'm also programming software to flash? I'm seeing conflicting info online and would just like someone to explicitly say what the offse...
15 years agoBoth the 'flash' boot code and the JTAG download work by running code on the nios cpu (from a block of internal memory) that writes copies the data into the required instruction space.
However, even if you aren't using the nios cpu to load the code, you may need data access to the instruction memory. The program '.text' section probably contains readonly data - look at the symbol table and/or request the linker generate a map file. The other fubar is the jump tables used for C switch statements, with gcc4 (as built by Altera) these are forced into the .code section - and there is nothing you can to do change this without rebuilding the compiler.
