OSeme
7 years agoFloating Point operation doesn't display the result
I am doing a simple test of the floating point functionality for the Nios II processor. I pass two integer numbers to Nios FPU2 and perform a square root operation and division. Result of the operati...
OSeme
7 years agoFound error. I should have used type casting since d1 and d2 are integers. Also, found another thread on this forum that says that Small C library doesn't carry float data type. If Small C library option is not chosen it looks like I need at least 41k bytes more of memory. Is there way around it to be able to use float and double data types?
