11 years agoFloating-Point calculation in nios
hi everyone,
i have read the " Using NiosII Floating-Point Custom Instructions Tutorial.pdf", it shows that use Floating-Point Custom Instructions can increase the Floating-Point calculate speed remarkably. but i can not find the "custom instructions" page in Qsys14.1. 1. how can i enable the Floating-Point custom instructions in quartus 14.1, is there some new version documents? 2. how can i know how many recources the Floating-Point custom instructions costs? thanks!!!5 Replies
1. there is a Floating point Hardware under Processors and Peripherals -> Co-Processors -> Nios II Custom Instructions -> Floating Point Hardware 2
2. after the design has been fitted, the resource usage is shown under "Compilation Hierarchy" in the top left corner of main Quartus window - Altera_Forum
hi, thanks for your reply.
in the " Using NiosII Floating-Point Custom Instructions Tutorial.pdf", there is a table https://www.alteraforum.com/forum/attachment.php?attachmentid=10598 the table shows that the nios can do lots of math, including exp log sin ... how these math can be done in nois? i find in the math.h : # ifndef _REENT_ONLY # ifndef __math_68881 extern double acos _PARAMS((double)); extern double asin _PARAMS((double)); extern double atan2 _PARAMS((double, double)); extern double cosh _PARAMS((double)); extern double sinh _PARAMS((double)); extern double exp _PARAMS((double)); extern double ldexp _PARAMS((double, int)); extern double log _PARAMS((double)); extern double log10 _PARAMS((double)); extern double pow _PARAMS((double, double)); extern double sqrt _PARAMS((double)); extern double fmod _PARAMS((double, double)); but i did not find the definition of these functions. - Altera_Forum
keep asking for help!
The Floating Point Hardware 2 supports about 17-18 single precision floating points operations only. - add/sub/max/min/div/mul/round/....
The functions in math.h is implemented using newlib, which is the standard C library. Nios will emulate these functions in software.
