14 years agoFlashed NIOS II SOPC not working?
Hi, I have developed an NIOS II sopc with multiple custom components. System works absolutely fine whilst operating in NIOS SBT for Eclipse (Debug or Run mode). However when I flash both sof &...
14 years agoWhat kind of function do your components implement?
There's only a situation I can think of: Usually when the design works in Debug/Run mode but not with EPCS boot, you have a problem with memory initialization. Infact, the jtag debugger automatically takes care of loading all the required memory sections, but with standalone mode (epcs boot) this is demanded to the bootloader. I remember a similar case when I had to add ALT_LOAD_SECTION_BY_NAME(memory_name) macros in my application to force loading TC memory which otherwise would have not been initialized.
