15 years agoFlash Access Problems
We have a 3 processor design that all boot successfully from a single CFI flash (all reset addresses are set to our CFI Flash at different addresses). The firmwares run in different On Board Memories...
15 years agoDSL,
Thanks for the further explanation. It sounds like you are a referring to some sort of firmware\software solution\control ?! Where can I find more info on this ? I was referring to the MUTEX component within the SOPC system, that I came across in the past but never really looked into...... Thanks again Shmuel
