15 years agoFlash Access Problems
We have a 3 processor design that all boot successfully from a single CFI flash (all reset addresses are set to our CFI Flash at different addresses). The firmwares run in different On Board Memories...
15 years agoThe SOPC builder (etc) arbitrates each individual bus cycle.
This is ok if all you are doing is reads. If you start doing writes and erases you need to ensure that no other accesses happen during the entire write/erase procedure. A sector erase is likely to take a significant fraction of a second.
