15 years agoFlash Access Problems
We have a 3 processor design that all boot successfully from a single CFI flash (all reset addresses are set to our CFI Flash at different addresses). The firmwares run in different On Board Memories...
15 years agoThe flash should be initialized if the following is true.
# if (!defined(ALT_EXCLUDE_CFI_FLASH) && ((!defined(ALT_USE_SMALL_DRIVERS) && !defined(ALT_SIM_OPTIMIZE)) || defined(ALT_USE_CFI_FLASH))) The easy way to ensure this is to just define ALT_USE_CFI_FLASH. In the BSP Properties under NIOS II BSP Properties add "-DALT_USE_CFI_FLASH" (without quotes) to Defined Symbols. I have problems when I have two BSPs for the same processor, but I am sure that is different than your situation. There is a global device list that should be filled out when alt_main() executes. Watch the global alt_flash_dev_list as you step through alt_main(). Since you are using three processors and I will be in the future, I have a question for you. I have seen some people saying that they cannot debug three processors at once, have you experienced this problem?
