14 years agoFile transfer to DE0-Nano running uClinux
Has anyone had experience transferring files via nios2-terminal, or other method, from a computer running Ubuntu to a DE0-Nano dev. kit running uClinux? My dev. kit is out-of-the-box, i.e. no etherne...
14 years agoYou can use the host file system, so that the software on the Nios is able to open files on the PC. But for that to work you need to be able to run the software through the debugger.
