14 years agoFILE * pointer declaration hangs uClinux
Hi all, I'm running uClinux (noMMU) on DE0 Nano. I'm trying to create a file and write to it via a C program. Example code: int main(void) { FILE * fp; fp = fopen("test....
14 years agoSo I was going to try your suggestions but first thought I would remove ALL other code in the program. It worked!! Beginner mistake. I'll have to start adding my code and see where the train comes off the tracks. If it is relevant to this post I'll report back. Thanks for your reply.
BTW, for other readers, the following code creates a text file and opens it for editing... int main(void) { FILE * fp; fp = fopen("/bin/test_data.txt","w+"); //your code here fclose(fp); }
