15 years agofft on nios
hello everyone. im working on speech recognition project using nios2 on de2 board. now i need to do fft to the signals i get from the audio codec. can anyone help with this ? how to conect...
15 years agoI agree, pulling samples out of a FIFO would be a much better approach. Haraim, if your audio interface does not have buffering built in I would recommend adding it. A common approach is to set a fill level on the FIFO that you use to alert the CPU that you have a block of data ready to go (FFT input size in your case).
