15 years agofft on nios
hello everyone. im working on speech recognition project using nios2 on de2 board. now i need to do fft to the signals i get from the audio codec. can anyone help with this ? how to conect...
15 years agoMost people use DMAs for this. So they put a block of data into memory and feed it into the FFT block by performing memory to streaming transfers. The output of the FFT block is then streamed back to memory using a DMA.
The reason for using DMAs is that if you are using dedicated hardware for the FFT calculation then you don't want a relatively slow processor in the data path. The DMA can handle moving a word of data every clock cycle which is a closer match to the FFT hardware throughput capabilities.
