We attempted to reproduce this issue on a Windows 10 machine but have not been successful so far.
The Tools team recommends trying standard Python 3.8.10, as it closely matches the Python 3.8.18 version used by quartus_py in Quartus 23.4.
Download Python 64bit 3.8.10 from:
https://www.python.org/ftp/python/3.8.10/python-3.8.10-amd64.exe
Run the Python installer after download completes. Select Custom Installation
uncheck Documentation
uncheck tcl/tk and IDLE
uncheck Python test suite
Click Next
Uncheck Associate files with Python (requires the py launcher)
Uncheck Create shortcuts for installed applications
Select Customized install location and use this path or any convenient short path.
c:\a\Python\Python38
Click install
Close
From command prompt:
cd <quartus installation>\niosv\bin\niosv-shell-files\
c:\a\Python\Python38\python main.py
As suggested above, set the PATH to minimal, we recommend installation to be at default c:\intelFPGA_pro\23.4 and run NIOS V shell.
- prashant_gohel10 months ago
Hi BB and Divya,
We have installed Python 3.8.10 as per your suggestion.
Initially, everything was working well — the Nios V console functioned correctly even after multiple system restarts.
However, today when I powered on my PC, I observed that the same error has reappeared.
Prashant Gohel
