8 years agoF2H Avalon Bridge f2h_sdram0_data_waitrequest got stuck
Hi all, I met a problem hope someone can help. I am using f2h_sdram0 to access the SDRAM. After building HPS system, I got the hps.xml file in handoff folder, part of the code is: ...
8 years agoHi guys,
I'm facing the same problem with a slightly different design. I have a Cyclone V SX with fpga2sdram enabled. Firmware is loaded by linux in userland with the device tree overlay method. My DMA accesses are fine but once in a while, the wait_request signal get stuck at '1' and I have to reset the board to get it back to a functional state. I have seen that there are several threads here with no answer from Altera. Also I found this article : https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/important_note_about_fpgahps_sdram_bridge; I'll be glad to know if the problem is on the die and/or if there are some tips/workaround to make it work. Cheers
