14 years agoExternal SSRAM reading/writing problem
Hello everyone, I want to connect nios core (cyclone ii) to external sram memory (cy7c1380d) but I'm experiencing a problem while reading/writing to/from the memory. For 2MB (data width 32 bit...
14 years agoHi, the problem appears to be fixed! As I said ssram_a6 and ssram_a7 were connected to A19 and A20, I changed it to point to the right pins. Also, I left ssram_a0 and ssram_a1 unconnected as SOPC Builder User Guide suggests when using 32-bit external device. Final pin connection order is then ssram_a2 to A0, ssram_a3 to A1,..., ssram_a20 to A18.
Thanks once again for leading me to the solution! Nikola
