15 years agoExternal SRAM instruction memory trouble
Hi, I have a program that seems to run in external SRAM. I am debugging using a hex display on a PIO port. I can write to the display, The timer interrupt service routine is executed. The main ...
15 years agoBrowse the forum. This is a FAQ.
You'll find a lot of similar issues, and solutions. Anyway, first of all check if you selected jtag_uart_0 both in project properties (as stdout device) and in the Run/Debug configuration (for Nios II terminal communication).
