22 years agoExternal bus interface
I'm trying to implement something similar to the MMC interface with the Nios II through DMA and/or Avalon bus. This interface consists of 1 clock and 5 bi-directional data signals. In the ...
22 years agoIf you use the default list it gives you and connect the ones you need you should be fine. Even if you come up with a good name for each signal, it's going to tack some extra stuff onto that anyway. The default list will give you port names like: nios_processor_read_n where nios_processor was the name of the core.
Leaving extra ports (like read_n) disconnected is fine, but you should have those assigned to meet the avolon bus spec (it's a standard bus so you need to follow some form of a conviention). Any logic that feeds nothing gets synthesized out so don't worry about using up more LEs adding the whole port list and not using all of it.
