16 years agoexpand a DM9000A Ethernet module
Hi,:) I use DE0 development board which is a simplification of DE2,but there are no Ethernet module on DE0 board. I would like to add the same dm9000 Ethernet module as the DE2 board on the DE0 ...
16 years agoHi, scola
To my opinion, drivers in Linux depends on devices or chips not board. Board selection in kernel config is to simplify the kernel selection. So, I think you can use your DM9000A IP Core and use the reference driver in Linux, if you're using a nios without MMU. But if you're using a nios with MMU, maybe the driver should be modified. If I am wrong, please forgive me :) --Smarter.UJS
