16 years agoEthernet on Neek running mmu linux question
Has anyone been able to get the ethernet on the Neek to work with mmu linux. So far I've been able to assign a MAC address, but when I give the command "udhcpc" it tries to assign an ip address. T...
15 years agohello,I have a neek board and nios2-linux-20100621.tar , I want to make an zImage with mmu, and I use the branch "truch" and "nios2mmu",when I compile the default configuration of the kernel,there is no error,.But when I change the configuration of the kernel and choose the Neek board,there is error is the process of compilation,can you tell me why? Thank you very much!
