16 years agoEthernet on 3C120
Hi, Does anybody manage to make the TSE run under uClinux ? I try what I read on the wiki, but I can't get a ping from or to the dev board (FPGA Dev kit 3c120). Do I have to use the opencore 10/...
14 years agoHi Actris,
I having somes problem with the 3c120 TCP protocol.. I am running uClinux by the way.. Currently I am using the .sof that came from the uCLinux tarball.. I was able to flash the board with the linux image and file system.. I can do ping from the board and ping to the board.. I have even hook wireshark to monitor the msgs... UDP/ICMP/ARP/DHCP seems to be fine but not TCP transmission.. I have seen from your post that you have resolve the problem. If you dont mind could I ask if you could share the quartus design file?.. Your quartus files seems to be diffrent compared to the design file that came from the altera wiki.. hope you could help.. --- Quote Start --- Hi mantoz, Did you select the : Ethernet (10 ot 100 Mbit) -> Generic Media Independent Interface device support. No need to select the : PHY Device support and infrastructure -> Drivers for Marvell PHYs. What size is your zImage ? bye --- Quote End ---
