16 years agoEthernet on 3C120
Hi, Does anybody manage to make the TSE run under uClinux ? I try what I read on the wiki, but I can't get a ping from or to the dev board (FPGA Dev kit 3c120). Do I have to use the opencore 10/...
16 years agohi,
i have a problem with my 3c120 dev board. i succesfully build kernel with uclinux 20090730 nommu dist. i boot the kernel from ddr2_sdram.when entered dhcpcd command, it stucks and timeout occurs tse interface doesn' t get dinamic ip from server. i use sof and ptf files which is located nioswiki simple socket server plus example, for building and running uclinux. i tried the board's ethernet lights lit but i can't communicate with ethernet. i tried giving ip with command shell, eth0 interface manually configured but i can't communicate with board via ethernet...please help me
