16 years agoEthernet on 3C120
Hi, Does anybody manage to make the TSE run under uClinux ? I try what I read on the wiki, but I can't get a ping from or to the dev board (FPGA Dev kit 3c120). Do I have to use the opencore 10/...
16 years agoHi Actris,
Which driver is selected in your "menuconfig" please ?? [*] Altera Tripple Speed Ethernet support (EXPERIMENTAL) or maybe this one : [*]Altera Triple Speed Ethernet MAC support(SLS) [*]Drivers for Marvell PHYs Furthermore, I saw in your SOPC Builder design that you named the components as follows : sgdma_rx, sgdma_tx, tse_mac, descriptor_memory Did you change some lines in your "config.c" or does it fit perfectly to the code ?? Thanks for your answer !!
