16 years agoEthernet on 3C120
Hi, Does anybody manage to make the TSE run under uClinux ? I try what I read on the wiki, but I can't get a ping from or to the dev board (FPGA Dev kit 3c120). Do I have to use the opencore 10/...
16 years agoclk_25khz1 - 25 mhz from eth_pll with phase = 0;
clk_25khz2 - 25 mhz from eth_pll with phase =180.00; In some articles or on forum i read that it has to be done the differences between the phase, but maybe i'am wrong. No, i don't use any OS. So, can you show your pins to TSE? If your rx works maybe i'am wrong in some moments with rx.
