16 years agoEthernet on 3C120
Hi, Does anybody manage to make the TSE run under uClinux ? I try what I read on the wiki, but I can't get a ping from or to the dev board (FPGA Dev kit 3c120). Do I have to use the opencore 10/...
16 years agoHi dim99,
Thanks for you answer. Does the ethernet works on your 3c120 dev kit ? Which driver do you use under uClinux (The TSE SLS, or the TSE Experimental) ? Regards, ------------------------------------------------------ from France with love...
