14 years agoError with 11.1 QSys sopc-create-header-file
All, I just wanted to bring to your attention that if you are attempting to use the 11.1 Quartus/NIOS to generate your uCLinux header files, you will run into the following issue. The comm...
14 years agoTo get around the issue, I would really recommend going back to 10.1 if possible...that seems to create the best header files.
