14 years agoError with 11.1 QSys sopc-create-header-file
All, I just wanted to bring to your attention that if you are attempting to use the 11.1 Quartus/NIOS to generate your uCLinux header files, you will run into the following issue. The comm...
14 years agoNo, the SR never went anywhere. I submitted the steps to recreate the problem, but I'm not sure it ever got submitted as a bug report. I eventually got fed up wit the lack of response and closed the SR.
Altera needs a better way to submit bug reports. I realize that they have to vet the reports, but blowing people off is typically not good practice.
