14 years agoError with 11.1 QSys sopc-create-header-file
All, I just wanted to bring to your attention that if you are attempting to use the 11.1 Quartus/NIOS to generate your uCLinux header files, you will run into the following issue. The comm...
14 years agoI just ran into this problem too. Any progress on your SR intermittent?
UPDATE: Problem is still present with 11.1sp2
