14 years agoError with 11.1 QSys sopc-create-header-file
All, I just wanted to bring to your attention that if you are attempting to use the 11.1 Quartus/NIOS to generate your uCLinux header files, you will run into the following issue. The comm...
14 years agofor an .sopcinfo file, add this to your ip-generate command:
--report-file=sopcinfo:<name>.sopcinfo
