14 years agoError with 11.1 QSys sopc-create-header-file
All, I just wanted to bring to your attention that if you are attempting to use the 11.1 Quartus/NIOS to generate your uCLinux header files, you will run into the following issue. The comm...
14 years agoHey intermittent,
Im facing a similar problem right now. In my case im using Qsys generating system and I dont know how to generate .sopcinfo files with Qsys. And well I dont know which is the command for Qsys to generate the header files. Thanks
