DPaul4
7 years agoError while loading rbf file from linux with overlay method
We are trying to load rbf using linux as per the method referenced in this blog https://forum.rocketboards.org/t/load-fpga-rbf-from-device-tree-overlay-example/999/17 However we are getting the be...
DPaul4
7 years agoHi, this issue is resolved by adding following change in
arch/arm/boot/dts/socfpga.dtsi. Now i'm able to load rbf
base_fpga_region: base-fpga-region {
compatible = “fpga-region”;
fpga-mgr = <&fpgamgr0>;
fpga-bridges = <&fpga_bridge0>;
#address-cells = <0x1>;
#size-cells = <0x1>;
I have added this in dtsi file. This seems to be not correct. Could we specify the (fpga-bridges = <&fpga_bridge0>;) modification in overlay? How to do it?
